i blew my headgasket on my d15 in my civic dx and i ended up throwing a rod through my block. so my question is will a d16z6 block work on the d15 head with no problems cause i found a full block for $75.
The comression is going to go down or it will stay the same with the dish z6 piston but it will work. What happen to the rod? did you hydrolock the engine?
doesn't matter if its a oe fel-pro type gasket just make sure it s 75 mm in the bore I think you can use on of a d16y8 to help rasie the comp back up 98 civic vetc ex
