d16z6 block with d16a6 head
Discussion in 'Engine Building' started by 90_EF_Hatch, Nov 29, 2007.
  1. 90_EF_Hatch
    90_EF_Hatch Señor Member
    Dallas Texas
    I finally made up my mind on what i want to do with my car. BUT...
    Will an a6 head work on a z6 block. Im using the ecu from the a6 already and i havent done any of the VTEC wiring so can i just put it on???
    I decided to repair the head from my old motor (a6) and put it on my z6 so i could then do work on my z6 head (new cams, port and polish, and ____). This is because i drive my car every day and cant put it out of commision for long. I then want to build up my a6 block and do a "Minin Me" conversion with the z6 head while i still have it off.
    Does this sound like a decent plan? or does someone see a problem.
    Also i need peoples input on parts and what not for my build.
    I was planning on using ZEX cams that they make specificaly for a z6, or does anyone else recomend a different brand? Also who should i go to to get my head port and polish done?? Should i do anything else to my head after that? And for my block i wanted to get new pistons for sure, but i am not sure what else i should do to it so im oppen to ideas.
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok you want a built minie in the end???what are you building for NA or turbo/nitrous???
    also whats the budget??
    after i know this i can give you a complete parts list right out of the tuners choice magazine
