d16z6 build i need help
acidwave40a
This is i have done to me motor now i plan on riping down the motor all the way and having the top and bottom end, redone.what kind of guts should i put in the top end and bottom ya i know it all depents on what im going to use the car for well im think there are really on only two i can show car or 1/4 mile but i also want to drive this car during the summer not everyday but most days so if you will help me out and u really know what u are talking about mean if u worked on the d16z6 motors or d's motors i need you help.
cold air in take--NPR ZC Pm7 P29 High Compression Dome Piston Set --D16Z6 Block and Head 12.15:1
EAGLE H-BEAM CONNECTING RODS
what else would be a good idea so i would have a good set up for a turbo
I would go with sum skunk2 internals a freind of mine had good luck with them + turbo but if u want a good N/A type R if they make it for that set up
