D16Z6 Combustion Leak Confirmed
jisakson
Member
Hey guys,
I did the combustion leak test, and it says I have a leak...
should I replace the head gasket with an aftermarket head gasket or a factory head gasket?
thanks guys
modded? if so, then replace with a cometic or something.
if close to stock, then go OEM metal.
OE Honda gasket FTW!
The price is a bit steep, but I take Chris's advice over any. I first told him I got a Fel-pro gasket and he yelled at me to return it. :laugh:
Are you absolutely sure it's the head gasket that's at fault? If it is, then definitely go OEM or Cometic if you need a weird size. Just make sure it's the head gasket that's causing the leak!
