chrism1829
Getcha Mind Right
I bought a car off a freind in my local area. He needed some cash asap and i decided to buy it off him.Heres the problems i am having
1989 crx d16z6 swap
runs fine and starts fine sometimes the check engine light comes on under a load or idle so i found out it was the
code 13
code 43
after awhile of driving it starts to get slugish after it heats up but still runs ok just need to give it more gas i thought it was the clutch but it graps right away.
What could be wrong with the fuel all it says is fuel supply system?..
and where is the BARO Sensor on the crx?
also the computer in the car is wrong i believe but i am pretty sure vtec works there is a pr4 ecu in it now and the distirbutor looks to be wrong still has obd0 plugs and only 1 bolt holding it in
any help would be great thanks
1989 crx d16z6 swap
code 13
code 43
