2 d16z6 heads-completely assembled vlaves,springs,retainers,rocker assembly,vtec sol. valve cover,waterneck-everything-you just need the manifold no bent valves,worked great before pulled also have stuff from a d16a6-shift linkage,axles,tranny,exedy stage 1 clutch,mounts,ecu make an offer on anything
i think i have 3-the drivers side,the passengers side,and the rear tranny with the bracket,,if those are what you mean,then make an offer.
