D16z6 Head Into D15z1 Bottom?
Terry_S
Hi everyone
question as topic, I had a D16Z6 head and want to put it into my D15Z1 bottom, doesn't it fit/work??
apart from the Z6 ECU, what else do I need??
Also, as far as I know, the D15Z1 piston stroke is different to the Z6, will it hit the values???
many thx.
Terry
it should bolt right on. the z1 is the vtec-e system, so you are all wired up all ready. the pistons won't hit the valves on the stock z6 cam
someone told me:
It will fit nicely. The only problem will be that your Z1 piston will have a deep dish. This means your compression is gonna SUCK! Like 8.2-8.4:1.
is it true??
Terry
so what heads will work with my d15z1 bottom end as ive been told that the origional head has small valves any help
im in the same situation i have a vei and really want 2 put a d16z6 head on do i use the d16z6 inlet and exhaust and ecu ? and what othe parts will i need thanx guys
