D16Z6 help
Discussion in 'Engine Building' started by H22 Fan, Jul 29, 2005.
  1. H22 Fan
    H22 Fan Member
    have
    stage 3 crower cam
    crower springs
    crower valves
    skunk2 retainers
    skunk2 cam gear
    arias 11:5:1 pistons
    need
    Eagle rods
    APR bolts/studs
    Stock seal and valve guides
    do i need a block guard?
    other than fuel management and tb and intake mani
    what else should i invest on
    and don't be wiseasses and say turbo
  2. H22 Fan
    H22 Fan Member
    [For IM, I'd sugest the Skunk2 with a B-Series TB, port match the IM to the TB.
    so buy a skunk2 intake manifold for a D Series and the B-series throtle body should fit it?? or will it have to be machined to fit??
  3. hybrid89
    hybrid89 thistownsucks...
    SoCal
    a b series TB will bolt right up to a d series manifold, but you will lose power if it is not port matched.
    matt
  4. H22 Fan
    H22 Fan Member
    so should i go with like an edelbrock or skunk2 throttle body
    RIGHT now im just buying all the parts for the motor
    i got a guy who's doin everything for 800$
    he gonna port n polish the head, mill 30th's , 3 angle valve job, machine rods 2 fit pistons, and put the sleeves in.
