d16z6 in a 94 dx
tylerk2311
ok here is the deal i need help i put a D16Z6 into a 1994 civic dx 30,000 miles on the motor it has a very bad problem with blow by enough to blow oil out of the oil cap when it is off i have done a compression test on each cylinder there is about 130lbs each ok the last problem it runs awesome but when you gas on it it smokes a little bit and smells like gas please help
youd get more help if this was in the eg section...and the gas problem is that your dumping way too much gas...the blow by might be because you have too much oil pressure or too much oil in the motor,,,
how could the compression be low i put the gauge in spark plug hole and turned the car over a few time and got about 150lbs per cylinder
