D16z6 Injector type & size
eXcelonTypeR
Ok, i've been doing searches on 3-6 different website forums including here, for bout 4-5 hours so i give up :ph34r: .
I want to build a z6 to handle enough boost to make 270-310hp, I been doing my research and I think I have everything I need except:
1. Injector size for a D16z6 (guessin 240?)
2. Are the injectors P&H or Saturated?
Any help would be great. :worthy:
I'm pretty sure (read as 95%+/-) they're 240cc and saturated.
Good luck!
Doh....edited....in all the places I've seen you'll never get that high of HP since the rods won't handle it. The bottom end probably could handle up to around 250HP if you went to a stronger rod, but the originals shouldn't be pushed over 200HP or 7500rpm.
I think a quick junkyard upgrade from a 86-87 D16A1 'teg would have a stronger rod....but only those years. They'll probably go the 250 mark.
