OK im an idiot for not thinking of any of this crap but heres my problems:got the motor mounted in last night, then i realized i forgot to get d series torque mounts. are they different between egs and eks or are they the same?
now for power steering. the y8 line that is in my car did not fit on the z6 pump, the hole on the pump is too small. so i tried putting the y8 pump on the z6 bracket, and it didn't work so wtf do i need to do about that? What bracket do i need to make the y8 pump fit?
And the throttle cable:
do i need a different throttle cable bracket? using the stock z6 one on the stock z6 manifold, theres too much slack in the cable even adjusted to the tightest setting.
what do i do?!
help please!!!
Also is there anything else i need to worry about? thanks!^_^
what do i do?!
help please!!!
