D16Z6 into CRX?
Discussion in 'HYBRID -> ED-EF / DA' started by crx D16z6, Nov 23, 2011.
  1. crx D16z6
    crx D16z6 New Member
    OK i need some help its my first swap never done it and now I'm stuck! i have a 91 crx hf shell well it had a h swap in it so the tranny welded bracket on the crx was moved over, i went out and found a d16z6, all stock just pulled from a 94 civic si.. i go to drop it in my crx well the si mounts are to big what do i do ? will stock crx engine mounts what ever comes stock on crx work i think d15b6 or d15a6 ? or do i get the after market civic to crx 91 mounts on ebay? Then what more do i need to know about dropping the d16z6 in my crx? will everything else work like wires they are obd1 wires! and p28 ecu!
  2. eg6sir
    go play in traffic
  3. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    Post in the correct area for the problem.
    If you can't do that, refer to eg6sir's post.
  4. phunky.buddha
    Dallas / Fort Worth, TX
