d16z6 manifold
Discussion in 'Civic and del Sol - EG and EK' started by fd3sdude, May 5, 2009.
  1. fd3sdude
    fd3sdude New Member
    Ok, Well im building a non vtec, Na build just to be different and see what number's i can get out of it, Well my question is, How much bigger is a z6 manifold then a d15b7 manifold, Im just looking to port match my z6 manifold but is it really worth it?, thanks.
  2. fd3sdude
    fd3sdude New Member
    So can any one give me any suggestions?
  3. GlassHeadlights
    Calgary, AB
    I would go for a whole Z6 motor or a Mini-Me swap. It would be super east with your shell. Just my opinion.
    D15B7s are kinda useless.
  4. fd3sdude
    fd3sdude New Member
    Well im building a sohc non vtec for a purpose not to be fast, That's why im asking.
  5. d-mon
    d-mon what r u compensating 4?
    if your purpose is not to be fast, just use the B7 manifold.
    ok?
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    why would you build a motor to not be fast???
    unless your doing an oem rebuild then that makes sense...
    but if your building for performance go aftermarket
  7. fd3sdude
    fd3sdude New Member
    Ok this is the thing, Im seeing what kind of number's i can pull out of this, not a oem build, Why cant i get a straight answer like i asked
    Did i want anyone's opinion on what to do NO, I asked if porting a z6 manifold is worth it.
    So if you want to suggest shit take your comment's some where else.
  8. GlassHeadlights
    Calgary, AB
    I'd say not worth it. Just put the Z6 manifold on as is.
    Maybe even a D16A6 cam, I heard its the best OEM SOHC non-VTEC cam, next to the SOHC ZC. But I don't even know if it would fit.
  9. fd3sdude
    fd3sdude New Member
    That's my plan for my DD, im having my a6 head sent off to exospeed in a couple of days, And that's what i was thinking but if i can get just a little more edge out i was just going to let maxbore do the port matching.
  10. d-mon
    the a6 cam will fit in a d15b7 head. both heads have the same casting.
    use a Y7/Y8 cam gear to compensate for the D15's shorter deck height.
