d16z6 mini me swap ?'s
mikey bottles
Prof. Bottles
getting ready to do a d16z6 mine me swap and just have a few general ?'s. 1st... does this swap require two 4 wire O2 sensors or just the factory single wire O2 sensor and the obd1 4 wire O2 sensor? i have the Hasport obd-0 to obd-1 wiring harness with the vtec subharness and obd 1 distributor harness... is this all the wiring required? also can i use the d16a6 intake manifold for this... or do i have to use the newer z6 intake manifold to match the head? Planning on using Arias ( Exospeed - Performance Parts for the Motor Enthusiasts ) pistions... any suggestions on rods? or are the factory d16a6 pistons sufficient? any info will help at this point... this is a whole new swap to me... thanks in advance
You only need one 4 wire 02sensor, and I believe you have all the wiring required.
Yes you can use your A6 mani with the Z6 head.
You should try out tuner toy rods.
Good luck!
