D16z6 obd1 harness on obd1 B16 in eg hatch
Discussion in 'ECU's, Electronics, and Tuning' started by bseriesautoparts, Aug 1, 2005.
  1. bseriesautoparts
    bseriesautoparts Junior Member
    Ok Tech guys I need some help....
    I have a 93 dx hatch with a built b16 (oBD1) swap with ITR tranny.
    I wanted to clean up my engine bay so I got a (upper) engine harness off a D16z6
    motor...
    All the plugs hooked up fine, but when it came to the starter there was no Black wire(with) /white stripe to hook up to the starter, so I ran a ground to the clip on the starter, but now when I turn the key I get .......
    the noisy ass [door open with the key in the Ignition, chime], all lites and gauges work and come on , heater blows, but when i push in clutch , and turn key, I get the fuel pump, main relay, come on, I hear the gas spray into the comb chamber, BUT thats it....no starter TRY'n to turn or nothing....
    Maybe the clutch inter lock, or what ?
    I need input asap
  2. hondagod98
    hondagod98 Junior Member
    Davenport, Iowa
    the black/white wire going to the starter is the 12+ from the key cylinder. It will come from a 2 pin plug next to the cannon plugs on the driver side front strut tower. hope this helps?
