d16z6 quick power add ons????
Discussion in 'HYBRID -> EG-EK / DC' started by lewellgd, Mar 24, 2008.
  1. lewellgd
    lewellgd 92CivicHatchCxBORNINCALI
    just bought a virgin 1992 si hatch---- decided not to swap the stock z6 out and was wondering if any one new what makes good power on these------ have not done nothing to it yet at all----- also i heard something about b series intake cam in d series???? sounds weird but if any one tried let me know---- just lookin to get good power out of my single cam so i can smoke some tegs and swaped hatches and say its just sohc---- THANKS
  2. BrutalB83
    Rochester Hills, MI
    I've never ever heard of anyone using B-series cams in D-series engines. For the most part B and D stuff is not compatible. I doubt it would work. Quite honestly, there is no cheap way to make power on a D-series engine, especially naturally-aspirated power. If you want to spank GS-Rs and swapped Civics, then I'd look towards a turbo setup...
  3. get_nick
    Washington State
    if you wanted a fast car, you should have bought something else. use it for a commuter car. if you want to race, just buy a b18.
  4. t3t4delsol
    t3t4delsol New Member
    York, Pa
    turbo it, turbo ds are fun to drive :)
  5. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    I agree. Buy some larger injectors, some type of engine management and a fuel pump and your ready to boost it safely.
  6. philyphreak2127
    philyphreak2127 Back in the Game
    Littleton, co
    Blanco somewhere in your signature you need to put d-series guru.
    With that said listen to Blanco is regarded as the d-series know-it-all. As for get_nick saying if you wanna race swap the motor...I disagree. The z6 is probably the easiest d-series motor to tune for good power. If you are looking to race this car 2 things you wanna look at before touching the motor with a turbo setup-arp head studs, and new head gasket. Past that I would agree with Ls_vtec, and Blanco.
  7. get_nick
    Washington State
    you can disagree, but it all depends on what you are trying to do. if you want a dd with good power, do what blanco did and do an all motor d. if you want cheaper power, get a turbo kit. if you want a track car, build an all motor b-series. keeping the front end weight down is a big factor in building a car. it isn't all about hp numbers. it just depends on budget, goals, and intentions.
  8. philyphreak2127
    Littleton, co
    um keeping the weight down? correct me if I am wrong cause I am not sure but wouldn't a d-series be lighter?
  9. get_nick
    Washington State
    i'm referring to turbo'ing the D. if you put a whole turbo kit, with front mount and all that, it's going to add a lot of weight to the front and throw off the balance. you will get a lot of understeer.
  10. LS_VTEC
    NJ
    It won't throw off the balance that much Nick. :)
  11. daveholiday
    daveholiday Do work
    Pittsburgh, Pennsylvania
    B16 Cams
    D16Z6 cam
    B series cams have 2, one for exhaust, one for intake. The lobes are designed for each.
    D series cam has a 2-1, intake and exhaust are both on the same single cam.
    If you put a B series cam in a D series, somehow I think you'd be left without either intake, or exhaust. Just somehow.
    If you want real power, get a bunch of APC stickers, and a very large spoiler, it'll add 10000HP instantly.
  12. 99civicJDMh22
    99civicJDMh22 New Member
    Austin, Texas
    i built my d16y8 before i put a h22 in it and i was raping alot of stuff Go to GUDE.com i bought a fully built head and cam package from them ported polished head, intake manifold, and throttle body. it comes with a mild cam and a little valve work. It real opened up my D. Before i put it on i went and had it milled at my local machine shop to run a little higher compression after it was all together i put adjustable fuel reg. ran a little more fuel and intake and full exaust and sprayed it with a 75 shot, make sure you have a good clutch, i had a exedy 3 puck. you think turbo is fun nitrous is fun and i spanked turbo d's all day long and gsr swapped hatches. It was fun to show the d and have people scrach there head lol.
  13. philyphreak2127
    Littleton, co
    what do you have against gude? just wondering I heard about that head package and was thinking about buying it.
  14. philyphreak2127
    Littleton, co
    alright I'll look into them thanks. Have you decided which way your gonna go with your z6 lewellgd?
