INJEN78
HS LEGEND
d16z6 in a 93 del sol si
all new gaskets in the top end(intake manifold,throttle body,head gasket)
just did head gasket and timing belt(timing is dead on)
firing order is correct
throwing a cel for the o2 but its been doing this
now i had swapped the z6 manifold for a y8..bolted everything together and started it up..it was surging,let the car warm,something popped and it idled fine.shut the car off let it cool.started it and it was surging..well the headgasket blew somewhere in the mix(i think that was the pop)
so i bought arp head studs,new gaskets and put it back together..well here we are at square one..the idle was surging from around 1400-1600 really quickly..
i turned the heat off in the car and it regulated at 1500 no more surgine..but now i cant get the idle to go down at all..
ive tried messing with the dizzy(ignitoon timing) ive double checked all my hoses and everything..even retightened all the nuts and bolts..idk what to do
