d16z6 swap/88 lx/ Can I use the z6 alternator?
esi42
Member
Hey all,
I have an 88 lx 1.5L, going mpfi/OBD1. I'd like to retain the stock z6 crank pulley and use the z6 accessories. The plug from my lx harness fits into the alternator on the z6 engine. If the pin locations are the same, can I use that alternator?
Thanks
Yes, I did the same swap, and there's no worries. I stayed OBD0, and used the 4th gen dist, but otherwise everything will just hook up and bolt up.
