d16z6 swap Elimination
Discussion in 'HYBRID -> ED-EF / DA' started by icwmanwillis1, Jun 3, 2010.
  1. icwmanwillis1
    icwmanwillis1 New Member
    Hey everyone my name is steven this is my first post and also my first honda.. I have a 91 dx hatch and am swapping for a d16z6 vtec I have done a lot of reading on what's required for the swap but my question I haven't seen a lot of answers for.. What all in the engine bay from the dx can go to the dump? What is not needed so I can clean the bay up.. Also I live in cullman alabama if anyone is interested in help with the swap and helping a noob learn more to do the job right.. I am willing to compensate $$$ for your time just hit me up and thanks for all the replys :)
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    You can get rid of the firewall-mounted MAP sensor. Other than that, I don't know what I took out; but I did move a lot of stuff around.
  3. D16SiHatch
    D16SiHatch New Member
    you can delete the evap canister also if you so choose.
  4. icwmanwillis1
  5. Chavezcraz
    Chavezcraz got bseries?
    Dayton, Ohio
    with it being the z6 i'm almost positive you'll have to delete the resistor box mounted on the driver's side fire wall. i'm almost 100% sure you have to delete this.
  6. icwmanwillis1
    Ok thanks I will look into
  7. K2e2vin
    Raleigh, NC
    DX's shouldn't have resistor boxes unless someone added it.
  8. Chavezcraz
    Dayton, Ohio
    crap, i was thinking si my bad
  9. crex16
    crex16 New Member
    hey bro have you completed this swap? if you are you think you could give me a hand . im doin the same swap and, well were stuck..hit me up thanks
  10. Oldskoolr
    Oldskoolr New Member
    Hey Chavezcraz, just wondering how the B18 swap is going... I am working on getting the info and parts together to do the same.
  11. d16z6swap
    d16z6swap New Member
    im in iowa doin that same swap in my 97 dx going through some tuff times with some sensor problems
  12. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    d16z6 is one of the easiest swaps into an ef. if you dont have emissions testing then yeah pull the evap canister out. take the firewall mounted map sensor off since its on the TB now.
