hi i want to swap a d16z6 into my 88 crx hf what is needed?
can i use stock trans,motor mounts ecu what can i use of theese parts that i have now and what do i need to change how do you wire up the vtec thanks for any info
yea you can use the stock mounts you will need to get a 92-95civic ex ecu, you can use the tranny becaus ethat tranny is geared very high and will make your car alot slower and it is also a very weak tranny look for a 88-91 crx si tranny
