esi42
Member
Hey whats up guys, I have just a couple question about swapping a z6 into my 88 lx.
I have a 93 ex parts car with a good engine and clutch with all wiring etc. I also have all the parts needed to convert my dpfi to mpfi: jdm zc intake manifold and dizzy, all plugs needed cut from an si harness, resistor box, and a pr4 ecu.
If i convert my lx to mpfi, i have to wire in the resistor box to use the obd0 injectors. Im going with the obd1 injectors and ecu, so my question is do I have to wire in the resistor box?
Then if i go obd1, could I splice in the cruise control from the ex?
On the 93 ex, there isnt a speedo cable, just a sensor there with a wire. Im going to be using a cable tranny. I know that if that sensor isnt plugged in, vtec doesnt engage. How can I show the computer the car is moving?
My last question, Im using the 14" rims from the 93 ex on my 88 lx. Could I swap over the larger calipers and rotors to my 88 lx?
Alright, sorry about the long post. Any comments appreciated.
Thanks
D
Thanks
D
