D16z6 TB on D16a6 Mani
Discussion in 'HYBRID -> ED-EF / DA' started by 8ballsin, Mar 10, 2009.
  1. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    i was told that all D series TB's fit on all D16 manifolds but i tried and the holes dont line up the D16z6 throttlebody the holes are further apart i have a extra Z6 mani will all the sensors mount on it from the A6 mani im running a 1990 CRX Si with Z6 swap and trying to get the idel fixed jumps from 1200 to 2000 when ever at an idel
  2. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    i unhooked the coolant temp sensor on the block in front and it idels perfect
  3. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    well idel jumps again so i unhooked iac valve and that fixed it so i am going to clean it
  4. 801CRX
    801CRX Got Rice?
    UTAH
    You can also use B series throttle bodies, just to let you know.
  5. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    b series anything is very hard to come by here in germany but thanks for the tip
