D16Z6 tranny bolting to a d17 ?
Discussion in 'Civic and del Sol - EG and EK' started by 2 slow del sol, Mar 14, 2009.
  1. 2 slow del sol
    2 slow del sol New Member
    nashville tn
    anyone done this? need to get my car moving and found a cheap 17. 93 del sol with d16 and new motor is 05 d17
  2. serrilion
    serrilion In my own little world! VIP
    Vermont
    Mite work. Some kid here just put a 00 trany on an older motor haha!
  3. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    should be fine, i have heard of people doing turbo builds using 1.7's cause they wanted that extra 100cc's. It's still a real D series and not an EW D series.
    You may have to swap out the head since it uses a series of coil packs for the ignition instead of a distributor.
  4. stmotorsports
    stmotorsports Senior Member
    Buffalo, NY
    NOPE. doesnt bolt up. Not even close. D17s are NOT 'real' d-series, they're completely different. NO parts interchange directly. You might get lucky and get 1 or 2 bolts to line up, but iirc the starter doesnt line up right either
    if you're stuck on doing the 1.7 your best bet is to run the d17 crank rods and pistons in a z6 or a6 block. And even thats not that simple.
    1 person likes this.
  5. Z6CRX
    Pittsburgh, PA
    +rep now i know :D
  6. RoboRex2005
    RoboRex2005 New Member
    Cleveland, Ohio
    That really sux, however the d17 trans dosent have the best gear ratios.
  7. stmotorsports
    Buffalo, NY
    true but the ex fd is nice... too bad it doesnt fit either
