d16z6 won't run
Discussion in 'HYBRID -> ED-EF / DA' started by Dark91zc, Jun 15, 2005.
  1. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    ok i have a 91 standard hatchback it has the dpfi to mpfi conversion harness on it and i made a standard/dx to obd-1 dizzy plug (was running dohc zc before) and i just made a obd-0 to obd-1 jumper harness now everything seems fine but when i go to start the car and the engine just spins and when i go to turn the key off the intake burps and the smell of burn fuel comes out. i hope this is a simple issue. cause in all of my swapping days i have not seen anything like this??? any ideas??
    thanks lance
  2. Dark91zc
    Corona,CA
    fixed it the obd0 to obd1 jumper harness had a crossed wire :)
