d16z6?
Discussion in 'Forced Induction' started by birdnuts6, Mar 26, 2004.
  1. birdnuts6
    birdnuts6 Member
    i recently acquired a d16z and was wondering if one of the two turbos i had would work on it....i have turbo off a volvo thats a tdo5-12b and the other is off an 87-89 supra.. iwas wondering if anyone had any kind of advice for the engine or if i should just try to find another turbo? pls any help would be greatly appreciated
    thanx
    b. kidd
  2. SolLess16
    SolLess16 Senior Member
    all depends on how you want to run your setup, need to be more specific? is it on a stock motor? are you gunna run 4pds or 18??
  3. birdnuts6
    birdnuts6 Member
    my bad i was actually wondering if anyone knew how much a stock bone d16z would hold. and if anyone had any advice. iave done some searches and well they are not very specific.. but i have gathered many ideas and it helps. thanks
    b. kidd
  4. bklyneg
    bklyneg Senior Member
    los angeles
    i think bone stock its no more than 8 psi, 9 is definitely pushin it.
  5. pissedoffsol
    read turbo 101, the sticky in this forum
  6. birdnuts6
    birdnuts6 Member
    i have read it...but what i was also wondering is if anyone knows maybe the amount of psi that this turbos might push out stock? or if anyone has any other information or any advice on what i should do pls let me know
    w. kidd
  7. pissedoffsol
    psi is pounds of pressure for square inch.
    what you just asked is along the same lines as "how much psi do my tires take stock".
    a huge tire will take more air (volume) to fill, even if it's still at 10 psi vs the dinky tire.
    turbos work the same way.
    larger turbos flow more air VOLUME (cfm) than smalelr turbos.
    psi is 100% MEANINGLESS and USELESS. NEVER EVER EVER EVER EVER make a psi level a goal, or a tuning limitation.
    Power breaks parts.
    not psi.
