D16z6
Discussion in 'Engine Building' started by shorty0o29, Jan 26, 2003.
  1. shorty0o29
    shorty0o29 Junior Member
    Is it possible to get say 160 or more horses with out changing pistons and other internals. mabey even get 150 to the wheels. Also is it had to change a cam? Could an averge person that knows a little about engines do it?
  2. Havok
    Havok Senior Member
    Florida
    With a helms, you can change a cam in no time...as for an z6 putting 150 + to the wheels, I/H/E won't do it, you will need a cam, an adjusted cam gear, rods, pistons, new engine :)
  3. mwasnp
    mwasnp Senior Member
    Hopkins, MN
    A greddy turbo kit would get you to around 160 whp maybe a little more...with good tuning atleast
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Most cams like the skunk2's recommend you changing out your springs and retainers,since your stock units are not going to be happy at the higher rpms,but yes adding around 50whp is very possible.
  5. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    You can find ZC pistons relatively cheap, should give you about 12-15 hp. Take off your ac, get a D16Y8 head gasket ( it's about half the size of the Z6) get a few small bolt ons, intake, exhaust, 160 easy.
  6. 88civicHBz6
    88civicHBz6 Senior Member
    turbo turbo turbo run a turbo with 6 to 7 pounds of boost and you pretty much got it.
  7. red95solsi
    red95solsi Senior Member
    Kansas City Missouri
    taking off the ac doesnt do a damn thing
  8. E_SolSi
    if you remove the AC system you are getting rid of at least 50 lbs of worthless weight and taking away a belt that is causing drag on the engine (even when its "free wheeling" its still added drag)
    how exactly will this have no effect on performance??
  9. machine
    machine Banned
    houston tx
    if no ac doesn't help how come F1 cars have none, or NASCAR, CART, etc???
  10. civicb18
    civicb18 Member
    IOWA
    id take it off if you are lookin for those extra horses, or atleast take of you belt, will give you about 5 hp, if you really wanna get serious, talk it all out for less weight as noted above
  11. 4doors4life
    4doors4life Senior Member
    South Pasadena, CA
    how much would a D16Y8 head gasket run? I have the same engine as this guy and looking for the same amount of power. Would this basic list be correct?
    Cams
    Pistons(springs & retainers)
    Y8 head gasket
    I/H/E
    and is that it?
  12. 88civicHBz6
    yep that's a start .
  13. 4doors4life
    South Pasadena, CA
    so how much would that head gasket go for?
  14. Havok
    Havok Senior Member
    Florida
    20 bucks new oem, manhonda.com
  15. 4doors4life
    South Pasadena, CA
    sweet. Thanks for the link!
  16. 4doors4life
    South Pasadena, CA
    I tried that site lookin for some ZC pistons but no luck...any other sites that would have em?
  17. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    Try looking on the parts trader .
    just do a ZC search and you should come up with a few things.
    Look through the miscellaneous parts lists.
