da6 backfiring metal sparks
Discussion in 'General Tech and Maintenance' started by y2kg0p317, Apr 28, 2007.
  1. y2kg0p317
    y2kg0p317 New Member
    look to the left on the fly way
    I was on the highway the other nite an all of a sudden my 90 teg started to loose power. she started to backfire and buck. when i looked back i could c metal sparking fling out. Noticeable piece of metal sparks. the car die n i pulled over. she tries to start but nothing. any1 got any ideas. need to get back on the road asap. help!
  2. formby
    formby learning in progress
    do you hear a gorilla in the block pounding its chest? ohh yeah it wont run
    maybe you blew a piston... any smoke?
    did you have oil?
  3. y2kg0p317
    im pretty sure she had oil i added 2 quarts about two days b4. was doin an oil change over the weekend. no smoke at all. she just lost power n die down, would turn over back. made all the right sounds to start but nothin.
  4. formby
    coil is prob gone
  5. y2kg0p317
    it turned out low oil pressure n the engines got it. thanks for the help
  6. y2kg0p317
    oil pump gave out, was just too old.
