Damn brake disks won't come off
Discussion in 'General Tech and Maintenance' started by Citizen_Insane, Mar 31, 2004.
  1. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    I cant get the screws that hold the brake disk in (the ones that are flush with the surface and mine are painted green) off. If i continue to attempt it, I will completely strip them. They're just normal philips head machine screws without a hex shape, so I can't use a ratchet on them. If anyone has any insight that would be great. Thanks.
    -Kai
  2. HellBentHONDA
    HellBentHONDA Senior Member
    wa state
    impact screwdriver- they sell em at most parts stores
    or
    a small hammer and a punch-unscrew it with these
    EDIT: oh and you definetly DONT want to use any type of air on them
    :D
  3. deth101
    deth101 Senior Member
    usa
    they make a special tool to take those off....your parts store should be able to help you
  4. HellBentHONDA
    wa state
    yeah. its called an IMPACT SCREWDRIVER!!!!!!!!!!!!!!!!!!!!!!!
  5. eml1618
    eml1618 Member
    If the impact doesn't work just drill them out. On my last car ('93 Hatch) we had to drill them just cuz they were so badly stuck. Def. try the impact screwdriver first though. And if you drill be careful. Here's an article that shows them drilling the screws out:
    http://www.overboost.com/story.asp?id=304
  6. reckedracing
    reckedracing TTIWWOP VIP
    NY
    the best way to do this is to take the philips bit from a bit driver, put it in its respective socket, then put the socket on a 3" 1/4 drive extension
    then take a big ass hammer and beat the shit out of it, then take a screwdriver and it should come right out with ease...
    or after you beat the shit out of it, just put the 1/4 drive ratchet on the end of the extension, the philips bit will most likely be stuck in the screw so leave it there until you've used the ratchet ot loosen it, then make sure you can get the bit out before you get the screw all the way out
    shock and unseize campaign...
  7. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    pb blaster first and let it sit for awile, then do what the posts above say and hit the end of the screw driver to break it loose some. apply a lot of pressure to the screw driver and then twist and if that doesnt work then drill them out.
