Dashboard???????
vtach1
Vtach attack
Will 95 civic coupe dashboard fit into a 91 crx
Sure, if you cut it and shit
why do you want to put it in?
the EG dash doesn't have the console that connects to the shifter like the CRX (you can buy one, but they're not cheap) and it has the passenger side airbag that you can't hook up...also if you break the trim that goes around the radio, you have to pull the dash back out to replace it
-then theres the wiring for the heat/AC and speedo...doesn't seem like its worth it
does it even come close to fitting
No. Not even close.
Technically, you COULD make it fit, with lots of trimming/hacking/modifying, but then chances are it's going to look like shit.
Not worth it.
