Hey, just figured I'd post up my 4dr gsr project and maybe get some input from some people.
The Setup:
mild port/polish
skunk 2 cam gears
aem fuel rail
aem FPR
RC 550cc saturated injectors, will need bigger very shortly.
cometic head gasket
new timing belt
darton sleeved
81.5mm bore
JE 9.1 Pistons
JE Rings
Manley TT RODS
ARP rod bolts
ACL main and rod bearings
blanced/micropolished ITR crankshaft
ITR waterpump
ITR oil pump
prodrive oil pump gear
Block gaurd
NGK wires/plugs
Act 2600 6 puck
Act streetlite flywheel
ARP Flywheel Bolts
Phantom grip lsd
For the turbo:
Full race ramhorn manifold
full race 4 bolt 3inch downpipe
precision SC61 Turbo
Tial 38mm wastegate 7psi spring
PWR FMIC
spoolin performance fmic piping, polished aluminum
Greddy type S BOV
GReddy turbo timer & profec b 2 ebc
walboro 255lph fuel pump
spoolin performance dumptube
Thermal R&D Turbo Catback exhaust
The pics:
The Setup:
mild port/polish
skunk 2 cam gears
aem fuel rail
aem FPR
cometic head gasket
new timing belt
darton sleeved
81.5mm bore
JE 9.1 Pistons
JE Rings
Manley TT RODS
ARP rod bolts
ITR waterpump
ITR oil pump
Block gaurd
NGK wires/plugs
Act 2600 6 puck
ARP Flywheel Bolts
Phantom grip lsd
For the turbo:
PWR FMIC
Greddy type S BOV
The pics:
