i am converting my interior to black, and i was wondering if the 94-01 integra carpet will fit in a 94 hatch.. i know the civic coupe/ hatch are the same on the inside pretty much.. but what about the Teg..??
Well it depends on how you install. I cut it down the front middle in the center since it was going to be hidden anyway. I only went half way since that was all that was needed, you might not even need to cut it if you unbolted the bottom half under the center of the dash. Take the styrofoam out of the donor car that helps mold the carpet around the shifter area. It will make sense when you're looking at it.
