DC GSR->EG CX
Discussion in 'HYBRID -> EG-EK / DC' started by SiR Racelot, Feb 8, 2005.
  1. SiR Racelot
    SiR Racelot Junior Member
    so i know a guy who wrecked the rear end of a gsr and now he's sellin parts. i already have a b16 with tranny and ecu. what parts can i take out the gsr to make the b16 swap complete? will the axles fit? i'm also thinking of taking his front and rear disc brakes...will this fit also? any help would be appreciated. thanks guys.
  2. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    yes to all your questions...lol
  3. civiclxb16
    Poconos pa
    all your b series parts you have in your car now will fit on the gsr motor the only thing you would have to check for is some wiring i think there is a couple of extra wires on the gsr engine then the sir engine not to sure only played with sir engines. but your mounts will fit, your axles will fit, your shift linkage will fit. and yes if the gsr is 94+ and your civic is 92+ the brakes will fit on the rear!
  4. SiR Racelot
    thanks for your help guys...how much money should i be looking to spend for the gsr shift linkage, axles, and f&r disc brakes? i'm also getting his sway bar...what other parts would be a good gsr -> cx upgrade?
  5. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    how about his seats
  6. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    How about ditching that B16 and getting the B18C.
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Whole suspension, motor, tranny, and all associated parts, seats, sterring wheel, and if you are patient the dash can swap too.
