DC Integra cluster swap
GlassHeadlights
West West Yall
I want to put a LS Integra cluster in my CRX because I like the look versus my stock cluster and I want the redline at 7000 RPM for my Mini-Me.
This is what I think I need...
Cluster
Plugs for back?
Electric VSS
Anyone ever done this or seen this?
I think I'm gonna do it!
Ya, I'm pumped.
Anyone know which vss I would use? I think a eg d-series one.
i believe you need the vss from a 96-00 civic. a 92-95 d-series vss will have to be modified.
here's the pinout i put together when i did my cluster swap
Cluster
Plugs for back?
Electric VSS
Yes, that's all you need.
I had bad luck using those pinouts online; looks like there's a difference between years or trim. I ended up tracing the wires though; nothing difficult.
You can use any of the electric VSS(B-series will work too if you swap the gear). I ended up having to use a 96-00 one because my transmission is a little different(DOHC ZC) and the 92-95 style wouldn't fit.
