Dead block pics, Rollerwaves = boom
Discussion in 'Engine Building' started by phunky.buddha, Dec 18, 2003.
  1. That's just standard wear y0!
    100.0%
  2. Holy shit that looks like hell&#
    0 vote(s)
    0.0%
  1. phunky.buddha
    Dallas / Fort Worth, TX
    Check it out everyone... if some of you have heard the rumors of my new block build screwing up, here's the proof. These are pictures that I took yesterday of my block and pistons. Take note that the engine was only running for 3000 miles. That's it.
    First link = Dead block pictures
    Second link = Import Builders Super Duper vs Endyn Rollerwave
    The links aren't TOO 56k unfriendly, but they are 2MB for the first link and 1MB for the second. Just give it some time to load.
    Discuss... what are your thoughts?
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Wow...
    Just wow.
    Does IB offer any "Super Duper" pistons without the sharp edges?
  3. mwvnos
    mwvnos Senior Member
    SC
    block def needs work....why dont you dec it to put less stress on the sidewalls....lol jk, pistons are nice. the higher the wrist pin, the better. the less angle on the rod, the better.
  4. lsvtec
    Except not, as the angle on the rod decreases torque production decreases.
  5. ek9r
    ek9r Senior Member
    Long Island NY
    damn dude, that sucks big time! is there any chance that there is a problem wit your sleeves that may cause this to happen? guess its time for a new plan huh? those IB spec's sure look purty :p
  6. phunky.buddha
    mvwnos- huh?
    Eric- not necessarily. The angle on the rod decreases, which is good for revving, but it doesn't necessarily mean that you get less torque. Sure, you lose some piston speed, but you also pick up some more dwell time at TDC and BDC. More dwell time means that you can fill the cylinder better with more air and fuel, which leads to more energy released on combustion because of more reactants and therefore more power... but then again, you have to optimize the engine a little differently too.
    The sharp edges on the IB pistons aren't really that big of a deal- you can smooth them out before you assemble the engine. I just like how Larry (Endyn) takes care of that for you without you having to guess at how much to remove.
  7. SixtySecondAssassin
    Austin, TX
  8. E_SolSi
    just dump a can of "Block Restore" in that shit you'll be fine ;)
  9. La_Pieuvre
    La_Pieuvre Senior Member
    Dallas, TX
    Mike,
    I didn't think it was that bad when you told me about it...
    Intercrew must love you by now, you're probably their best customer.
    Oh well, get it fixed and give me a ride in the beast next time you're in town :)
  10. brc80
    brc80 Senior Member
    Southern California
    :bo:
  11. pissedoffsol
    boost it. :) fuck this all motor blowing up shit :)
  12. Tonyd0821
    Tonyd0821 Banned
    so....in layman's terms...
    how did you blow ur engine? :D
  13. B16
    B16 Super Moderator VIP
    yay area, CA
    that sucks man! :(
    i wanted to see that monster with headwork done.
    you seem to be taking it well though, i'm sure these mishaps are not cheap.
  14. phunky.buddha
    It'll get there, don't worry. And don't worry- it costs me a lot less than you might think.
    :lol: :lol: :lol:
  15. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    how the fuck does it actually cause that kind of damage? ring but putting out enough pressure and just letting the piston slam the wall?? Rod angle too extreme for the ring load???
  16. phunky.buddha
    I'm not too sure. Larry over at Endyn says that the bore must have been sized wrong, but it checked out at the machine shop just fine. I don't know.
    The rod angle is actually better than my old B20 build, so I don't see how that would matter. The rings actually sealed better than the old ones, so that can't be the problem either. I really think that the short skirts let the piston rock around in the bore too much...
  17. h22bubbleback
    h22bubbleback Senior Member
    North Jerzey
    :withstupid:
  18. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    that sucks man, hope everything works out with the next motor.
    as a side note buddy of mine sent Larry his block for complete rebuilding, sleeves, rods and pistons, etc.. short version: after about 5k his rod went right through the block, not saying that it can't happen but me personally I just don't consider larry a choice for engine building.
    but best of luck man.
  19. statiksol
    statiksol Banned
    are you sure there wasn't anything wrong with your oiling system?
  20. phunky.buddha
    Yes, I'm sure. <_<
