brian11to1
Some of you know...
Im building a 93 B18A1 (Integra) engine...
So far I have a set of B16 pistons on LS rods w/new Total Seal Rings, Hondata Intake Manifold Gasket, all new seals and gaskets, STR cam plug, OEM bearings, Cometic 2 Layer Headgasket, STR Fuel Rail, B&M FPR, JDM ITR header, PnP LS head, Crower Springs/Ti Retainers.
Im wondering if I should get these parts...
Skunk2 IM, Modded (for my sedan) RSR exMag exhuast, Catco Cat, Adjustable Cam Gears, JG 301's or Crower 62403's, Koyo del Sol Radiator, Fal Fan.
IM - I would definetly benefit from it, but do I absolutely need it?
Adjustable Cam Gears - I dont know if Ill be doing much more to it after this... so.. are they needed?
Cams - Ive searched on the JG cams, and havent found anything... (JG's) but the 62403's are awesome, from what Ive heard...
Input is greatly appreciated...
