Decided on Exedy stage 1 clutch/flywheel
Discussion in 'General Tech and Maintenance' started by BigBoy, May 22, 2005.
  1. BigBoy
    BigBoy Senior Member
    cali 818
    My question is which kit do i get?
    This one
    or
    This one
    I have a 1991 civic hatch with a b16
  2. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    If you have a b16a1 as in jdm, get the clutch for a 90 integra, i can't see what u linked, so if so get the 90 integra one.
  3. Estorvito
    Estorvito Soy Boricua
    Orlando FL
  4. BigBoy
    cali 818
    yea its a jdm b16, 1st gen head 2nd gen block. I emailed the guy thats selling them to see which app is right for my car and he said he needs to know the disc size and spline size??
  5. BigBoy
    cali 818
    BUMP
    Theres also a kit that says its compatible with any jdm b16a with y1 or s1 cable trannys....i have a j1, will they still work?
  6. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    If you are using a b16 cable tranny y1, s1, then you need the 90 teg clutch. If you are using a b16 hydro tranny, I think you can use a 94+ del sol dohc vtec clutch.
  7. APACHE
    APACHE Junior Member
    ATLANTA, GA
    I believe u r right....
  8. BigBoy
    cali 818
    im using the j1 cable tranny. I think its identical to the s1. Thanks
