Hello everyone.
i've allready finished b18 swap to my Del Sol and there is some problems with hood...
when its closed my engine adjoin to hood.... I's this normal ? Or maybe its somethig wrong ???
The b18 engine sits to high. You will need to cut a bit out of the hood. Just cut a notch of the framing/support on the inside of the hood. Take a little bit of metal out until it fits.
Or, you can put washers under the hinges until it fits.
Thanks for replys I thing the awptickes denouement is the best for me, because i cant buy hasport mounts in poland... only way to get this mouts is to buy them in usa(ebay) and send to poland this is very expensive and it will be persist a lot of time(sth like 8 weeks ..) i dont have time 97hatch i have left, right and front mounts OEM b18c1 and rear from civic SIR....
I've installed a few days ago Edelbrock intake manifold but not the Performer x but Victor x, i dont have turbo i have N/A setup, i'm wondering how it will be work after the adornment.
you can use the tranny mount from any integra for the b18 swap into a del sol. ive done the swap and i ve used both honda mounts and hasport mounts. if you use the honda or hasport it should not have that problem.
