yes 3rd gen integra brakes will work
you will need the entire hub/rotor/caliper/lines/etc... probably easiest to take the whole trailing arm from the teg and might as well get the LCAs to
you will also need e-brake cables, im not sure if the integra ones work or if you need them from a del sol Si or VTEC
