Del Sol VTEC Radiator into '91 hatch
B16CRX
if you are refereing to the small square rad there is quite a bit of midification to be done to get it in there. You have to cut the lower support back a couple inches, and if you want to use the mounting bracket with it you have to do some mods to the hood as well.
Yeah a friend of mine has this setup on a rex, and I know that the fabricator who works for him made him an upper custom bracket and cut out something underneath. A piece of the cross memeber im guessing, but not sure.
two rows? is one the AC condensor? Im just using a 92-95 civic on my crx. I have to trim back some of my lower rad support and move one of my rad mounts.
