delay timing
Discussion in 'General Tech and Maintenance' started by mozzandherb, Jun 26, 2005.
  1. mozzandherb
    mozzandherb Senior Member
    I've heard that if your running nitrous you should retard your timing depending on how much the shot is, however I also heard that if you advance your timing you can gain a little more horsepower now I don't know if that's with or without nitrous. Anyway my question is when I add the nitrous should I retard the timing even if I'm just using the nitrous and the track twice a month? I drive the car daily so I don't know if it's a good idea to delay it if I'm only going to use the nitrous once and a while.
  2. formby
    formby learning in progress
    for every 50 shot 2deg retard.....use a colder plug....ngk bkr7e is what i use....and i retard the timing only when i know i will use the nos...which is sat night and track days....nos is not something i would recomend using everyday...specialy on stock internals....
