delima delima
Discussion in 'Civic and del Sol - EG and EK' started by bigturbo, May 19, 2008.
  1. bigturbo
    bigturbo New Member
    Crossroads of engine management
    Ok I have run into a road block on my motor swap. here is the situation
    I have a 5 speed 95 del sol with a d15. I have a US spec b18b1 complete swap(5 speed) with the wiring harness still attached and the stock ECU. I found out I can use the obd2 harness as the tower plugs are the same so nothing is cut and the six plugs are all in tact. I bought an ecu I was told was for a 94 integra LS 5 speed and the code is p75-a51. I took the man at his word then found out the A51 designates it as an Automatic ECU. So at this point I have 2 ecus and dont want to buy yet a 3rd. So to me I have two options. maybe I am missing some other option you guys can give me
    1 buy hondata the obd1 auto ecu and plug n play which with install and tune is about ($900.00) bucks but this would allow me to boost later when I get to that point
    2 buy an ecu jumper harness($125.00) in my car to run the us obd2 ecu that came with the motor. I feel like I could then plug n play but that I would need to install a second 02 sensor for the ecu. I was also reading about the CKP sensor and was not sure if I would have to wire for that(i know its on the car but would the pinout be in the right place after the obd2 to obd1 back to obd2 conversion?
  2. dacheat
    dacheat ..is grounded.
    strongbadia
    a dilemma is a problem offering at least two solutions or possibilities, of which none are practically acceptable; one in this position has been traditionally described as being impaled on the horns of a dilemma, neither horn being comfortable..
    :slap: carry on :D
  3. get_nick
    Washington State
    i see we have a new grammar/special nazi. i'm not ready to turn this over yet. we can share. ^_^
  4. dacheat
    strongbadia
    eh, there were just two really awful and readily available examples of spelltardation that needed addressing and it's a monday at work (read: anything but work, plz). you can keep the title, i'll just offer my services once in a while :D. this particular one made me remember the "put de lime in de coconut" song and that's why i had to say somethin. i'm ruined for the day now, can't get it out of my head.
