delsol swap questions!
jbones1.8
doing a swap for a lady friend and was wandering if any of you have done the auto swap...
it going into a 93 honda delsol si auto...the motor is a b16a auto from japan..
was curious to what all i would need to complete the swap?
the motor did not come with a harness, will i be able to use the d16z6 harness?
hey if you fellas have any info that would be helpful that would be great, please reframe from the smartarse remarks!
thanks jay
you're going to have probles if the tranny is cable, ie, the SiR 1.
if you got the sir2, it should simply bolt in, run the p30 with the swap, and run the wire for the knock sensor. its pretty straight forward.
You mean refrain. :lol:
Just to clarify- are you trying to keep the car automatic?
Originally posted by pissedoffsol@Jun 14 2004, 03:56 PM
yup.
sel;l the cable b16 tranny and pick up a 94+ auto teg LS tranny for dirt cheap.
hey im looking into a ls tranny know....anything else i might want to know!!!
hey, found a ls tranny but was reading you post on b16a in to a 92-95 civic you said that you would need a obd1 distributer....
https://hondaswap.com/forums/index.php?showtopic=29812
will the b16a distributer not work?
what mounts will work in the delsol?
will i need the 90-91 integra rear mount bracket?
will skunk2 chip a p28 automatic ecu?
to keep ac, what setup would you need?or what compressor bracket is needed?
sorry if im pestering you fellas, just would like to know.
You say the motor is a auto B16A from Japan, and her car is an auto Delsol Si, so where does all this talk of cable come in?
