minitruckin
ok first off i am new and i really need help. i recently did a jdm h22a swap in my 96 accord ex coupe. i did all the wiring, changed over to a manual tensioner, replaced timing belt and water pump, installed a p13 ecu with jumper harness, used the accord throttle body with map sensor and made the throttle linkage bracket. my problem is that the car is not running on cylinder no. 2. checking with a heat gun it only gets to about 100 degrees. also did a compression test and every cylinder comes in below 90 pounds, with no. 2 below 60 pounds. the car seems to run decent at idle with a little shake and you can definitely tell it has a miss. need to fix this car asap as its my only transportaion and i need to visit my son out of town. any help would be awesome and greatly appreciated. thanks
