Did I get screwed?
Discussion in 'HYBRID -> ED-EF / DA' started by crombie09, Jan 4, 2004.
  1. crombie09
    crombie09 Member
    I was cleaning the outside of my supposed Si tranny tonight and saw L3 on the case. Thats not a 5 speed Si tranny is it? -crombie09
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    L3? wat the fuck does that mean, theres a code stamped somewhere but I don't know where its at. i dont think 5 speed trannys had codes like that, but I'm not sure someone here will though.
  3. crombie09
    crombie09 Member
    pl3 9000, is that what I need to know for sure? -crombie09
  4. Jeef
    Jeef NO MA'AM Moderator VIP
    L3 means manual tranny. I think that all of the ef manual trannys have l3 on them. The si does have l3 on it but it has a different carrier bearing marker on it. I can get pics of it if I remember.
  5. crombie09
    crombie09 Member
    Ok went out to the garage and looked again.
    It has:
    pl3 9000
    l3 2585690
    on it as well.
    Is there a place a should be looking on the tranny that would tell me what it is? -crombie09
  6. jlicrx
    jlicrx Senior Member
    Colorado Springs
    all 88-91 Civic, CRX and ZC transmissions (4spd & 5spd) are L3 models - PL3/9000 is more than likely a Si, but not definitely - the PL3/9000, PL3/3000, etc. are casting numbers for the back half of the case and can be used to determine whether the transmission has the large or small bearings (PL3/A000 have small bearings) but do not indicate the gearing - for instance, I have a ZC that is PL3/9000, did have a 91 DX that was PL3/3000 and had a 88 Si that was PL3/A000 - the only way to know for sure is to check the gear ratios
  7. crombie09
    crombie09 Member
    Damn good info bro! The only way to check out the gear ratios is to put the trans in the car, right? -crombie09
  8. jlicrx
    Colorado Springs
    don't have to put it in the car - shift the transmission into reverse - rotate the input shaft and count the number of turns the input shaft makes to turn the differential one complete turn - 9.3 turns=HF: 12.25 turns=DX: 13.4 turns=Si
  9. mspeedyb
    mspeedyb Junior Member
    im thinking its jus a tranny off a del sol. b16a3's jus a guess though
  10. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Just stop posting.
