did i install the neuspeed koni sp3's right?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by greenteg2k00, Mar 21, 2004.
  1. greenteg2k00
    greenteg2k00 Senior Member
    i finally installed with my bro neuspeed koni on my integra gsr 2000, can you take a pic of your car of how the shocks should look like installed, because i finally install shocks, its weird the front became higher than before, before i had neuspeed race springs with stock shocks which sat low, and after i installed the neuspeed konis with the neuspeed race springs, and the height raise a little, its not as low as before is this normal, did you have the same problem, i didnt have time to install rear, will do when i have time
    i heard a pop noise, but its gone now
  2. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    probably have the wrong springs for your car or something like that
  3. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    no the springs need time to settle
  4. vtecsir1
    Orlando, FL
    that settle shit isnt accurate
  5. spicer
    spicer Junior Member
    you've definatly got the wrong springs...i change mine when they 'settle'.
  6. UDT
    UDT Senior Member
    california
    Well aslo you said you had stock dampers befor, there may have been alot of squat from running the lowering springs on the stock dampers, thoughi would make 100% sent sure there the right springs.
