did the b16a2 swap any body switched
TWISTEDIMAGE
have you put the b18c1 block togher with the b16 head any thing need to be moddified or is it a direct swap
also i do not want a ls block somthing about no griddle or oil squiters i just dont get along with i know you can add this stuff to the ls
but i want to know about the gsr block to the b16a2 head
and maby if you knw what kind of hp numbers are we talking about
That's a poor mans type R engine, except with milder cams and a non PnP b16 head.
the swap should be a direct one.
id keep the gsr head. IAB's are your friend!!
the combustion chamber on a 1.8 gsr is smaller than a b16 by the way! i remember lookin into this for fun months ago.
Yes the GSR head yeild a higher combustion ratio, and as far as the IABs, well, that's preference, I'd get rid of them, drop in some CTR cams, a light PnP, and swap to a chipped ECU.
