did they ever make a hydro prelude transmission?
civicious
Buck Futter
VIP
did the obd1 preludes have hydro transmissions? i thoght i read somewhere that they were only available in cable...
the trans is hydro.... the "cable" in question is the Shift linkages... they do not have a solid linkage like a Civic... they have 2 cables that run from the shifter to the tranny..."hydro" means how the clutch is engaged...
i can see how it could be questionable
hope that clears up the confusion
No, transmissions can be cable-actuated as well, like some of the B-series trannies.
All F-series and H-series engines use hydraulic transmissions. They never came with cable trannies.
Edit: EGLSHB, I see what you mean now. Transmissions can be either hydro or cable, and shift linkages can be either solid or cable. Later Prelude/Accord engines all had hydro trannies with cable shifters.
:doh:
thats what i meant...
so all preludes have cable shift linkages?
