dieing issues
Discussion in 'HYBRID -> ED-EF / DA' started by chadcharb, Jun 25, 2010.
  1. chadcharb
    maple valley, Wa
    so the gf's ef sedan is having a problems were the car just dies when she is driving. the battery was bad so i got a new battery and the problem persists. so i thought it was the altenator and put a volt meter on it and its putting out over 12v still. its a stock d15 with dpfi.
  2. danny shy
    danny shy New Member
    try the main relay
  3. Dual-500
    Dual-500 Well-Known Member VIP
    Fort Worth, Texas
    What is over 12v? Alternator should push 13.8v if all is well. If it's under 13v I would take it to the parts store for a load test.
    Many times, when a battery goes south it takes the alternator with it - sometimes the alternator is the cause of the battery taking a dump by not charging it correctly.
  4. chadcharb
    maple valley, Wa
    it was 14v. I'm gonna pull it and have it tested tomorrow
  5. Dual-500
    Fort Worth, Texas
    ok - if it's cranking our 14v it's fine.
    I would start looking at the distributor - sounds like mine when the sensor that times ignition went kaput. Sometimes it only had issue (miss) in one cylinder. Then other times it would randomly die. Sit for a few minutes, then start back up.
    Good luck with it.
  6. chadcharb
    maple valley, Wa
    i went back to look at it today and now it wont fire at all. its throwing a code 16 gonna look that up
    16- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-95 88-95 n/a 88-91 93-95 95 88-95
    Fuel Injector System
    defective circuit or unplugged / defective fuel injector
  7. Dual-500
    Fort Worth, Texas
    Wiring check - ground and connectors. Also, those diagnostic self tests don't always nail it 100%. Strobe signal could be missing for injectors.
    Look for sensor - in mine it's in the dizzy - your model may have a separate sensor on the cam or crankshaft for the injector strobe signal.
    You're getting closer.
  8. chadcharb
    maple valley, Wa
    replaced main relay...problem solved
  9. Dual-500
    Fort Worth, Texas
    danny shy gets the prize - you nailed it!!!
