differance between 15x6.5 and 16x7
Discussion in 'Wheels / Suspension / Tires / Brakes' started by sinezter, Aug 31, 2007.
  1. sinezter
    sinezter New Member
    wadup, im planing on gettin some rota slipstreams, but i would like to kno the differance between the 15'' and 16''
    the 15'' is 6.5''
    and the 16'' is 7''
    what would be better? and what is the differance from the two besides size and weight... like what benifit would u get from running the 7 insead of the 6.5?
    thanks, i couldnt find this answer anywhere
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Ability to run a wider tire without the sidewalls leaning in
  3. eg6sir
    i'd get the 15x7 slipstreams
  4. sinezter
    sinezter New Member
    why?, because of the weight?
  5. eg6sir
    because of the wider rim and having it allow you to run a wider tire.. but i guess it depends on what you plan on using the car for
