well, lets find out....*whips out his eagle catalog*
well the rods are different. or at least the part numbers are
Rod length 5.394, 1.771 crank pins, .826 piston pin, .935 be width
part numbers are different.
LS part #CRS5394A3D
B16 part #CRS5290H3D
Couldnt tell you want the difference is.
and after checking out zealautowerks.com, they say that the LS rod is 3mms longer than the B16. Someone needs to stop confusing reiko.
